Laptop Hewlett-Packard HP 250 15.6 inch G10 Notebook , Cpu : 13th Gen Intel© Core™ i3-1315U × 6 Os : LMDE 7 - Cinnamon 64-bit!
As vrea sa ii dau un update la bios si nu stiu de unde sa incep! ![]()
dmidecode 3.6
Getting SMBIOS data from sysfs.
SMBIOS 3.5.0 present.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: AMI
Version: F.15
Release Date: 01/08/2025
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 9 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
ACPI is supported
Smart battery is supported
BIOS boot specification is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 15.15
Firmware Revision: 61.43
Handle 0x002D, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 5
en|US|iso8859-1
fr|FR|iso8859-1
es|ES|iso8859-1
zh|TW|unicode
zh|CN|unicode
Currently Installed Language: en|US|iso8859-1
Am erorile astea in logs : sudo dmesg | grep 'error'
[ 7.756762] ACPI Error: Aborting method \_SB.WMID.WQBZ due to previous error (AE_AML_BUFFER_LIMIT) (20240827/psparse-529)
[ 7.756771] ACPI Error: Aborting method \_SB.WMID.WQBE due to previous error (AE_AML_BUFFER_LIMIT) (20240827/psparse-529)
[ 7.772952] ACPI Error: Aborting method \_SB.WMID.WQBZ due to previous error (AE_AML_BUFFER_LIMIT) (20240827/psparse-529)
[ 7.772963] ACPI Error: Aborting method \_SB.WMID.WQBE due to previous error (AE_AML_BUFFER_LIMIT) (20240827/psparse-529)
[ 7.795297] hp_bioscfg: Returned error 0x3, "Invalid command value/Feature not supported"
si am citit pe "goagle" ca trebuie update la bios!
